100% Isopropanol liquid class
When trying to aspirate 100% isopropanol, I always get a liquid level not found error.
Is the only option to do a fixed height aspiration? Reluctant to do so to avoid over-submerging the tip. Any help is greatly appreciated!
Just to rule out, did you try to use pLLD instead of cLLD?
Did you try high/very high for cLLD?
Good suggestions, I’ll also add that turning off liquid following can help a lot with this type of error.
Late follow-up: thank you so much! This worked.
Thank you!!
