When I click on the Advanced button, I can not see the window pop it is hidden
How can I fix this?
it’s for Sort… Sequencing
@Kabha - The window is likely popping up on a non-visible display. This is sometimes due to previous display settings applied from use of an additional monitor that is no longer present. I’ve had this happen to me a few times with various applications.
You should be able to recover the window to your display by following the instructions below (opening the advanced sequence window first):
