I was just wondering if there was a way to make steps of specific libraries show up as different colours? I know that we can customise to change the colour of error steps/comments/disabled steps, but I’d like to have that freedom with other libraries too, including self-made ones. Is that possible, either in venus or in the code of the library in HSL?
Thanks
Tarun
Hi @tarun.chapman,
While it isn’t possible to adjust the line colors for libraries, it is possible to change the image that appears on the left side of the command:
This example is a sub-method library made in Method Editor called “MettlerToledoWXSController.smt”. To get the icon to appear next to the commands, I made a bitmap of the image I wanted and named it to match the sub-method library name (MettlerToledoWXSController.bmp), as seen below.
If the sub-method library in question is open in Method Editor, then close and re-open to make the icons appear.
Hi Dan,
Thanks for the response. I’ll do that instead, thanks
Best wishes
Tarun
