Disable front cover opening at deinitialize
is it possible to deactivate that the auto load front cover is lowered at the end of a run during deinitialize? Since this is part of ‘end method‘, I cannot raise it as part of the method.
SYSTEM : End method - start;
Microlab® STAR / VANTAGE : Clean up instrument - progress; Move down auto load Y drive
SYSTEM : End method - complete;
Vantage / STAR V
Cheers,
Martin
Hi Martin,
If you’re running Venus 6.3 or later, you can use the disable clean up step that Eric mentions here:
Hi @stpipettor,
thank you so much, this works perfectly.
Kind regards,
Martin
