I’m working on a sample preparation method (In GxP environment).
It’s should be ready for validation, however at the end, when End method is running, I get a Vector error “SYSTEM : End method - error; An error occurred while running Vector. The error description is: Catastrophic failure (C:\__w\13\s\Vector\src\HxMethodCopy\code\HxMethodCopy\MethodDeps.cpp:198) (0x46 - 0x10 - 0x1)”.
This path maybe doesn’t exist anymore?
The method executes correctly, PDF report is generated without errors, just this little error then lives in the trace. Run history also shows the method as aborted.
Any ideas how to identify this error will be greatly appreciated.
