How to pick up a plate and put it back on the same location in Bravo?
Hellooooo! Adding a new way of changing the teach points rather than creating a new separate profile. Technically you can use registry() to overwrite the teach point value by applying the offset to the location you want to move around BUT you need to re init the profile to reflect the teachpoint change so at this point maybe just use cmd to overwrite it. As long as you change it back it should be ok!
