Serial dilution help
Good evening,
I got my STAR about 2 months ago and I’m very happy with it so far. I’ve already developed a few straightforward protocols, and we also added our LVK, which helped a lot with accurate pipetting.
Now I would like to develop a serial dilution protocol based on a worklist, something like this as starters for me to understand:
The logic itself is straightforward:
  • Check liquid class (this part is already working thanks to the LVK) ; lets assume water for now.
  • Then dynamically create the sequence depending on the requested dilutions
For example:
  • If sample 1 has 2 dilutions (1/10, 1/100), then execute those
  • If sample 2 has only 1 dilution (1/10), then execute only that
  • If sample 3 has 4 dilutions (1/10, 1/100, 1/1000, 1/10000), then execute all four
What I’m struggling with is the dynamic construction of the sequence itself.
Does anyone have advice, examples, or a similar protocol they’d be willing to share?
I am currently playing with the add sequence and loop to add to the sequence based on loop counter. So far, no success haha
Thanks you all!
I’d recommend searching the forum, this is a very common type of question. I don’t know if there’s a single pre-existing answer but it can help to see what other people have tried. Have you checked out SeqLib and DevLib? These are common libraries for handling imported worklists.
