Washers/dispensers
It’s definitely best equipped for just the ethanol wash steps. Since the plate is on a permanent magnet the beads can’t be adequately re-suspended even if you had your EB hooked up the C.Wash. Plus depending on how important your final concentration is, it’s means of dispensing is not super accurate. In my experience it needs to be paired with a more capable liquid handler to truly be effective.
Seconding what @STomp said. The resuspension was the big thing in my hands, needing a shake or tipmix after and it was just easier to have that happen with the liquid handler the C.Wash is integrated with.
It’s a bit wasteful to have the C.Wash do it just because of the need to prime through the internal fluidics between each reagent swap. It’s not an astronomical volume but something to keep in mind for process development. The BlueWash does come with optional dedicated dispensers, but since the comb is not shared I’ve found that you have to be more mindful of clogs if the device has been sitting (and you’re using reagents that might crystalize or whatever).
That said, an on-deck magnet can help pull down the beads before it gets put onto the C.Wash. It can also help for downstream applications where you might not want bead carryover.
Just received the info from Cytena (provider of C.WASH) that they don’t sell the magnetic carrier for the C.WASH anymore. People now need to purchase the G.PURE from Dispendix for magnetic bead clean ups, which is also more expensive than the C.WASH. Just wanted to mention this in case someone was thinking about buying the magnet plates. I am now looking into engineering my own magnet plate for our C.WASH…
If you are familiar with the Certus Flex then they’ve got a new dispenser and washer all in one coming out.
It was shown at SLAS 2025 San Diego.
Not sure when it will be fully released.
I was told that the release should be October/November…
Nice :slight_smile: Is the aspirate adjustable enough to use it for cell-based assays?
I believe it should be because the Certus Flex is mostly used for cell based assays.
anyone who has made experience with the 406 FX and maybe even in comparison with the EL406? I barely find use-cases about 406 FX. Is this because the market is flooded with EL406 and everyone has their instrument and doesn’t want to upgrade for more or less no reason or do people simply not need the extra dispensing channels? I also don’t understand why Agilent is selling both - they could have just replaced the EL with the FX?
N.
