Locked: This thread is a duplicate of Mixing within the Liquid 1000uL Channels, discussion has been moved there.
I’ve looked around at other threads to see options for how to get a fixed height dispense mix to be submerged in the liquid but haven’t quite pinpointed how to go about this. I saw that apparently for a fixed height dispense, the mix position parameter isn’t actually used (?). Currently the tips rise completely above the wells between mixes.
Thank you!
