64-bit to 32-bit communication tip
A common problem I’ve noticed is that automation hardware often uses 32-bit DLLs for communication. This can be annoying because it sets a limit on memory usage and many libraries (like Python’s scipy) aren’t compatible with 32-bit.
One work-around is to use a server running in 32-bit that can talk to the 32-bit DLLs, but receive HTTP requests from 64-bit processes. Nothing crazy complicated but this has come up so often for me that I figured it might be helpful for other people. Here’s an example:
class COMClient:
    def __init__(self):
        self.client = None
    def ensure_device_exists(self):
        """Initialize the COM client connection."""
        if self.client is None:
            import win32com.client
            self.client = win32com.client.Dispatch('BMG_ActiveX.BMGRemoteControl')
            self.client.OpenConnectionV('CLARIOstar')  # Replace with your connection parameters
    def execute_and_wait(self, activex_args):
        """Execute and wait method on the COM client."""
        self.ensure_device_exists()
        self.client.ExecuteAndWait(activex_args)
# Create a global COMClient instance
com_client = COMClient()
def create_server():
    app = Flask(__name__)
    CORS(app, origins=["*"])  # Allow any origin
    # Initialize scheduler and runtime with database directory
    @app.route('/execute-and-wait', methods=['POST'])
    def execute_and_wait():
        data = request.get_json() or {}
        activex_args = data.get('activex_args')
        com_client.execute_and_wait(activex_args)
        return jsonify({
            'success': True
    app.run(host='0.0.0.0', port=5100)
Great post, this also highlights the beauty of standardized communication formats for hardware. You can abstract the messiness away.
We’ve come into issues with this recently too. Nice solution, at least for where you can use python.
Why don’t manufacturer’s upgrade to 64-bit architecture? It’s existed since the 1970s!!!
Not in itself an issue but can also be seen as an example of an indicator that shows that our field still has a long way to modernise and improve.
I’ve never gotten into this w/ python before - do you need to specify somehow that your python script and interpreter are running in 32 bit? How do you do that?
And how would you know if you’ve got a conflict? I’m trying to do this w/ Agilent’s ActiveX dll, I can use win32 and makepy to get the COM objects. But when I try to use them, I keep getting “Class not registered errors”.
Should have googled…
Now I have a 32bit python env running, but still not able to use the COM objects.
