The Microlab PREP is designed to be an affordable first step into automation or companion system to your existing setup. Share questions, best practices, helpful files
Does anyone know if it is possible to change the order of addition when filling a 384 well plate. right now its does each column, I would rather go through and fill it up by Quandrant, so Q1, Q2, Q3, and then Q4. Or even better tell it only do go to Q3 for the entire plate. Is there a way to do this with out a worklist?
@Michael_Vuke - tagging you as the Hamilton expert.
Hey Denise, with the new software update (available now!) I believe you can specify pipetting order in your hitpicking worklists, which should let you have that flexibility ![]()
@denise you could also use the “replicate samples” step and do a custom selection. That would work without needing a csv ![]()
Ill give this a try!
