Alternative ways to generate random (integers) numbers in Venus?
HSLRandom returns an unknown error…while i investigated the source code of the lib, the error occours on CheckObject and LibraryCOMObject functions/variables. Venus originally reports the error at line 349. Specifically, venus returns: invalid characters.
Venus v4.4.0
HSLRandom 2.0.0
There may be an installer that needs to be run with HSLRandom (I dont have it so can’t say for sure) - have you run that? If it’s to do with CheckObject, it may not be able to create the instance to the COM registered object
Hi Gareth
Thank you for your time!
looking at the installer of Venus 4.4, i noticed there is a COM object library
which is installed
Ah sorry, I meant there may be an installer for HSLRandom specifically, not the COM object library for Venus itself…
The HSL Random library requires its own installer to be run - see this link to download. I just tested it right now on a new setup with the functions you have in the image and it worked without issue.
Oh, found it
HSLRandom Library Installer version 2.0.zip :: Hamilton
tryin again
Thank you Eric!
Unfortunately my company is blocking .zip downloads but now i know that we may have an issue with our local installation
