I was just wondering if there are any users of the BioMicroLab VC384 by sptlabtech? If so what is your experience with them?
I would be interested in those who have used this as well
I’ve used it, though mostly just for testing its capabilities - didn’t get as far as integrating it into any production workflows. Overall, the experience was positive. It definitely takes a little bit of work to dial in new labware (creating definitions, adjusting calibration curves, etc.) so I wouldn’t expect to get perfect readings right out of the box (SPT support was helpful here). Unsurprisingly, it worked best with labware that has tall, straight-walled wells; specifically 1mL FluidX tubes had the most accurate readings out of everything I tested.
@OliverSanderson I agree that it takes a bit of work to dial in new labware. I have found that the software tends to be a bit buggy. Here are a few observations I have made:
At times, when creating calibration curves all data points will plot in a concentrated area of the map and/or in a vertical line.
Sometimes the door will continuously open and close while attempting to read a plate.
A plate of uniform volume may read high/low in multiple locations. Power cycling the instrument and reading the same plate will yield expected results.
I’ve got a VC384 integrated with a Beckman Coulter i7. I’ve used it in production for several assays to read / validate volumes in plate assays. It’s been absolutely perfect every time. Last project was 11k samples in ~400 plates.
I found it very easy / intuitive to set up and create a calibration curve to measure volumes. Had some input from a service engineer but really the manual says everything you need.
I will echo what @OliverSanderson said wells / tubes with long straight walls are easiest. The calibration curve creation is flexible though so you should be able to get a good match as long as your container has a simple geometric shape.
@frederikromer I’m glad to hear you’ve had success with your VC384. I agree the simpler geometric shapes are easier to calibrate. How did you go about integrating your VC384 with the i7? Our VC384 is standalone at the moment but I would be curious to explore integrating it with our i5.
@tbever we paid Beckman Coulter to integrate the VC384 alongside a larger integration including Scara robot, incubator, plate washer etc. This was before SPT bought BioMicroLab.
I know you used to be able to buy ActiveX integration kit from BML. I would assume SPT still offer this. However, we calculated that it was cheaper to let BC integrate compared to getting the kit from BML plus labour cost of having our team code the integration. Your situation may differ.
For those that have had lots of experience and success with a VC384, I am curious if you have dealt with asymmetrical labware. I am currently considering going down the rabbit hole of deviating from default dimension settings and troubleshooting with offset values to see if it may help tighten up data points, but would be interested to hear of other’s experiences first.
@tbever What do you recommend when you get the issue of the instrument door closing and opening without end at times? I tried power cycling with various combinations of computer vs equipment and still nothing.
@cendvincent Sorry for the delayed reply. I’ve been on PTO and it’s been awhile since I’ve checked the forum in general.
I have encountered instances where the door will open and close perpetually. I don’t recall what the apparent cause was though. Have you made any adjustments to the z-height of the labware definition?
Yes, I made adjustments on the z-height. It has happened before but it recovers quickly. This time, it was like this for days so I reached out to the vendor. Vendor said that the sensor is busted in many words.
@cendvincent You may want to try changing the z-height back to its previous setting to see if that eliminates the issue. Granted, I think you would have to create a new calibration curve but you could at least determine if the height change is the cause.
Alternatively, I have also been down the rabbit hole exploring/troubleshooting other sensor related issues (if that is in fact the issue). I have had back and forth calls with their support where we were making command line changes to various sensor settings. Unfortunately I haven’t seen good documentation about how to implement those changes as an end user.
Hi tbever.
- If you are getting datapoints in a vertical line, it could be due to the gain, or the wrong plate settings. If you restart the calibration and that works then it looks like a bug!
- I think you might know now, but If the door opens and closes, its checking the sensor is performing as expected by measuring a reference point at the top of the plate, and checking its within the accepted tolerance. You can run this test in the device control tab under sensor test.
You can still buy the SDK and documentation, but your correct for an integration if you have a supplier its likely easier to get them to hook it all up. This way then can deal with both hardware and software integration in one go.
Yes that is right, it sounds like the sensor is struggling there. There are some internal settings service can help you modify the sensor parameters, but these are typically no open by default.
