Hello everyone, I am running into an issue when the LH is loading the carrier it is not scanning the tips. Even though in the advance step I have it specified to check positions 1, and 2. Any help/advice would be greatly appreciated.
Hi @automation_viome ,
The carrier that you are using does not enable barcode scanning by default. I would recommend swapping the carrier for the TIP_CAR_480BC_A00 version.
TIP_CAR_480BC_A00
TIP_CAR_480_A00
The difference is the property MlStarCarNoReadBarcode is set to 1 for the non-barcode scanning option. This tells the system that it can load the carrier, but not to scan any barcodes.
THANK YOU!!!
