Hey, often, at the exact same point in a script we run a lot, we get an error that the TeChrom Shuttle (mini-purification Fluent component) needs to initialise again. We get the error in driverframework as opposed to fluentcontrol. does anyone know how to do automatic error handling when the error is occurring in driverframework?
you can “bridge” errors - but as the driver is controlled via Driver Framework (DFW), that application handles the prompts on an error,
Given the error occurs at the same part of a specific script, I would be inclined to suggest troubleshooting the command that creates the error,
i have completed various development projects to replace driver framework drivers with a better control structure capable of incorporating full error handling - the shuttle device is one of those where we removed DFW and replaced with an alternate driver mechanism
