PyLabRobot is now asynchronous, based on Python’s asyncio. This will make the implementation of complex methods significantly easier.
Each operation can be awaited using await:
await lh.aspirate(...)
or
fut = lh.aspirate(...)
# do something else in between
await fut
In IPython/Jupyter Notebooks, you can use await directly.
In scripts, I recommend using asyncio.run():
import asyncio
async def my_method():
asyncio.run(my_method())
One of the many neat features of asyncio is gather, which can be used to run two actions simultaneously:
async def pipetting_sequence():
await lh.dispense(...)
asyncio.gather([
pr.read_absorbance(...),
Depending on the model of robot, running two ‘active operations’ (such as aspirate/dispense) simultaneously might raise an error. This is the case on STAR. You can, however, aspirate while performing ‘passive operations’.
This is amazing! Congrats!
This is great Rick, I was actually postponing writing the Klipper backend because it relies on asyncio. This greatly simplifies things.
A quick feedback on my experience with using-the-simulator.ipynb. Everything seems to work except for the following:
- Cell 21:
set_well_volumes is not awaitable, and it raises an error.
- Cell 32:
(tip_car[0].resource) is not awaitable, and a TypeError is also raised.
Bonus: unrelated to asyncio but possibly helpful.
- The included screenshots seem outdated and led me to some minor confusion.
- An effect of dropping tips is that they placed back into the tip racks: is this the expected behaviour?
- The simulator looks a bit off, I’m using Chromium:
Amazing work!
Thank you! Great to hear!
- Cell 21:
- Cell 32:
Fixed in fix simulator nb · PyLabRobot/pylabrobot@57c9f51 · GitHub.
Fixed in update simulator screenshots · PyLabRobot/pylabrobot@965ee3b · GitHub.
Yes. discard_tips is to permanently dispose of the tips (thinking about renaming this to dispose_tips).
Fixed in fix hamilton star simulator layout · PyLabRobot/pylabrobot@8357907 · GitHub. (I should really figure out a way to add UI & unit tests to the simulator…)
Thanks a lot for reporting these!
