Build hybrid sequence 2mL/15mL using seqAdd
Hi everyone,
Small bug here that blocks me:
Using an excel, I want to efficiently build a sequence on the fly that encompass 2 tubes racks: 1 rack 2mL, 1 rack 15mL. I did it in a very complex way and I am trying to get that done smoothly in a few lines. Basically:
The user uploads his CSV using a prompt. The CSV contains a column that specifies the tube type with which we are dealing:
I iterate over the file, read and load all the info into arrays. Everything works fine.
On my deck, I have 2 tube racks:
-tubes_2mL_to_aliquot
-tubes_15mL_to_aliquot
It is on those racks that I want to create the hybrid sequence. To do so, I create 2 variables that correspond to those tube racks, along with 2 variables for the positions on those respective racks:
While reading my file line by line, if the sample_content type is a tube 2mL, add it to the rack 2mL at the position 1, otherwise, add it to the rack 15mL at the position 1: Then, add +1 to the position to generate the next position:
The sequence is visible in my variables panel:
After checking, everything looks fine:
Still, I get this error:
Any idea?
Regards,
I think I got it: Converting my positions into a str as SeqAdd takes Str for positions:
Will leave it here in case someone needs it one day.
