Communication, Cannot switch loading light on / off
Running into this error out of nowhere.
Does anyone knows how to fix this and what the reason of this Error is?
Already tried to restart PC & Robot as well as run Run Control as admin.
Found the solution: this cable is too Long and has been broken over time & use:
In order to use the robot without the lights one can deactivate «Loading indicators» the following way:
  • Open STARService.exe
  • Settings
  • Instrument Configuration
  • Next
  • Uncheck «Loading indicators»
  • Press Next until Finish
Now you can use the robot without lights on the front until your service engineer replaces the cable.
