Creating TADM Traces from Star Tip Tools Library
I am working on a formulation application & am able to create pressure traces for the various aspirate & dispense steps from component tubes into a single prep tube
i need to mix the single prep tube and wanted to create a pressure curve for the mixing step - I have been using the PIP_MixFromFixedHeight command
But using this does not appear to trigger pressure recordings,
is there a different approach I should use to mix & record the TADM pressure ?
Hi @Optimize ,
The PIP_MixFromFixedHeight is unfortunately not compatible with TADM. TADM data can only be generated using the standard ML_STAR Pipetting steps.
Note: pre/post mix steps of aspiration/dispense commands also do not generate TADM data. TADM recording begins at the actual pipetting step.
