Following Standardized labware naming convention discussion and Remove Resource's that don't have a catalogue number or other identifier (sept 1) · Issue #170 · PyLabRobot/pylabrobot · GitHub, we are removing all resources that do not have a “[correct] PLR-definition of the physical object + metadata needed to use it” (@CamilloMoschner’s definition) because they are practically unusable. I imported a bunch of resources that qualify as “undefined” from venus, which I now deprecated. They will be removed September 1st.
If you still want to use the resources that were deprecated here, please verify that the definitions are correct and update them with a catalog number and associated documentation.
By crowdsourcing, we are building an actually reliable and usable database of labware.
