Hoping for some help writing a method to aliquot solution from a trough and dispense in a gradient across a 96-well plate
I want the dispense to go like this:
Column 1 contains 100ul of solution
Column 2 contains 105ul
Column 3 contains 110ul
Etc
I have a method that increases the volume by 5ul for every well (method and trace file below) but can’t figure out how to make the volume change per column (or after every 8 wells?). Would really appreciate any and all advice.
Method:
Trace:
2024-02-14 10:15:43> Microlab® STAR : Initialize (Single Step) - start;
2024-02-14 10:15:43> Microlab® STAR : Initialize (Single Step) - complete; > channel 1: Waste, > channel 2: Waste, > channel 3: Waste, > channel 4: Waste, > channel 5: Waste, > channel 6: Waste, > channel 7: Waste, > channel 8: Waste,
2024-02-14 10:15:43> Microlab® STAR : 1000ul Channel Aspirate - start;
2024-02-14 10:15:43> Microlab® STAR : 1000ul Channel Tip Pick Up (Single Step) - start;
2024-02-14 10:15:44> Microlab® STAR : 1000ul Channel Tip Pick Up (Single Step) - complete; > channel 1: HT_L_0001, 1 > channel 2: HT_L_0001, 2 > channel 3: HT_L_0001, 3 > channel 4: HT_L_0001, 4 > channel 5: HT_L_0001, 5 > channel 6: HT_L_0001, 6 > channel 7: HT_L_0001, 7 > channel 8: HT_L_0001, 8
2024-02-14 10:15:44> Microlab® STAR : 1000ul Channel Aspirate (Single Step) - start;
2024-02-14 10:15:44> Microlab® STAR : 1000ul Channel Aspirate (Single Step) - complete; > channel 1: rgt_cont_120ml_a00_0001, 1, 100 uL > channel 2: rgt_cont_120ml_a00_0001, 2, 105 uL > channel 3: rgt_cont_120ml_a00_0001, 3, 110 uL > channel 4: rgt_cont_120ml_a00_0001, 4, 115 uL > channel 5: rgt_cont_120ml_a00_0001, 5, 120 uL > channel 6: rgt_cont_120ml_a00_0001, 6, 125 uL > channel 7: rgt_cont_120ml_a00_0001, 7, 130 uL > channel 8: rgt_cont_120ml_a00_0001, 8, 135 uL
2024-02-14 10:15:44> Microlab® STAR : 1000ul Channel Aspirate - complete;
2024-02-14 10:15:44> Microlab® STAR : 1000ul Channel Dispense - start;
2024-02-14 10:15:44> Microlab® STAR : 1000ul Channel Dispense (Single Step) - start;
2024-02-14 10:15:44> Microlab® STAR : 1000ul Channel Dispense (Single Step) - complete; > channel 1: Nun_96_Fl_Lb_0001, A1, 100 uL > channel 2: Nun_96_Fl_Lb_0001, B1, 105 uL > channel 3: Nun_96_Fl_Lb_0001, C1, 110 uL > channel 4: Nun_96_Fl_Lb_0001, D1, 115 uL > channel 5: Nun_96_Fl_Lb_0001, E1, 120 uL > channel 6: Nun_96_Fl_Lb_0001, F1, 125 uL > channel 7: Nun_96_Fl_Lb_0001, G1, 130 uL > channel 8: Nun_96_Fl_Lb_0001, H1, 135 uL
2024-02-14 10:15:44> Microlab® STAR : 1000ul Channel Dispense - complete;
2024-02-14 10:15:44> Microlab® STAR : 1000ul Channel Aspirate - start;
2024-02-14 10:15:44> Microlab® STAR : 1000ul Channel Aspirate (Single Step) - complete; > channel 1: rgt_cont_120ml_a00_0001, 9, 140 uL > channel 2: rgt_cont_120ml_a00_0001, 10, 145 uL > channel 3: rgt_cont_120ml_a00_0001, 11, 150 uL > channel 4: rgt_cont_120ml_a00_0001, 12, 155 uL
2024-02-14 10:15:45> Microlab® STAR : 1000ul Channel Dispense (Single Step) - complete; > channel 1: Nun_96_Fl_Lb_0001, A2, 140 uL > channel 2: Nun_96_Fl_Lb_0001, B2, 145 uL > channel 3: Nun_96_Fl_Lb_0001, C2, 150 uL > channel 4: Nun_96_Fl_Lb_0001, D2, 155 uL > channel 5: Nun_96_Fl_Lb_0001, E2, 0 uL > channel 6: Nun_96_Fl_Lb_0001, F2, 0 uL > channel 7: Nun_96_Fl_Lb_0001, G2, 0 uL > channel 8: Nun_96_Fl_Lb_0001, H2, 0 uL
2024-02-14 10:15:45> Microlab® STAR : 1000ul Channel Dispense - complete;
2024-02-14 10:15:45> SYSTEM : Execute method - complete;
2024-02-14 10:15:45> SYSTEM : End method - start;
2024-02-14 10:15:45> Microlab® STAR : End method command - start;
2024-02-14 10:15:45> Microlab® STAR : Clean up instrument - progress; Move up 1000ul channels
2024-02-14 10:15:45> Microlab® STAR : Clean up instrument - progress; Move up CO-RE 96 Head
2024-02-14 10:15:45> Microlab® STAR : Clean up instrument - progress; Move down auto load Y drive
2024-02-14 10:15:45> Microlab® STAR : Clean up instrument - progress; Spreading channels
2024-02-14 10:15:45> Microlab® STAR : Clean up instrument - progress; Switch off loading lights
2024-02-14 10:15:45> Microlab® STAR : End method command - complete;
2024-02-14 10:15:45> SYSTEM : End method - complete;
