Hello!
I’ve faced strange problem. We have generated worklist like
A
D
D
D
W
A
D
D
D
A
D
D
W
A
D
D
D
W
1st, and 3rd tip aspirates once, while 2nd does it twice, without changing DiTi.
Everything is ok, before I check “TAG after each dispense” in LC.
Once I did so, Evoware crashes right before second aspiration with 2nd tip.
Hi I don’t know why you get an error, I have only tried making multi-dispense like this:
Maybe you could see how this works if it is not too much trouble.
Already solved.
The possible solution is forcing liquid class without TAG in last dispense like this
A;
D;
D;
D;…LC;
A;
D;
