EVOware logfile firmware commands guide
Hello all,
I work with the Freedom EVO platform and our primary liquid handlers consist of single and dual arm (mostly 8span) instruments. I’ve done troubleshooting and support on these instruments for the last year. I’ve noticed that neither the evoware software manual, nor the s&s service manual contain detailed information about how to read the firmware commands within the evoware logfiles.
If it exists and if possible, could someone please share a guide or manual on how to read the firmware commands within the evoware logfiles?
Ash
Each device has it’s own command set
I can upload files - which devices do you have ?
By device, do you mean the arm configuration? If so, we have EVO Freedom instruments with the following arm configs: MCA96, LiHa (Fixed & DiTi), as well as instruments that contain a RoMa arm. Let me know if I’m misunderstanding what you mean by devices.
Thanks for the help,
Ash
Uploading the firmware commands (or at least the useful ones) to the wiki would be a great addition.
I’ve got instruments with the following configs: MCA96, LiHa (fixed and ditis), and a few instruments with MCA96+RoMa
You might try reaching out to your FAE if no one here picks up the torch or has the documents. The FSE will have access to those references.
Greetings,
reviving this old thread just in case anyone is able to help with finding a Firmware user manual for Standard EVOware.
It would help me tremendously with troubleshooting errors.
Appreciate it very much
EVOware doesn’t have a specific firmware user manual - firmware exists on a per module basis,
which modules are you specifically interested in ?
