Evoware worklist only uses one tip
Hello friends,
I am trying to work with a new Evo150 and I’m learning the scripting. I have written a worklist to try to move liquid from wells on one plate to another just as a test. This is my worklist:
A;Source;;96 Well DeepWell square UMAS;1;;100;;;;;
D;Dest;;96 Well DeepWell square UMAS;1;;100;;;;;
A;Source;;96 Well DeepWell square UMAS;2;;100;;;;;
D;Dest;;96 Well DeepWell square UMAS;2;;100;;;;;
A;Source;;96 Well DeepWell square UMAS;3;;100;;;;;
D;Dest;;96 Well DeepWell square UMAS;3;;100;;;;;
A;Source;;96 Well DeepWell square UMAS;4;;100;;;;;
D;Dest;;96 Well DeepWell square UMAS;4;;100;;;;;
A;Source;;96 Well DeepWell square UMAS;5;;100;;;;;
D;Dest;;96 Well DeepWell square UMAS;9;;100;;;;;
A;Source;;96 Well DeepWell square UMAS;6;;100;;;;;
D;Dest;;96 Well DeepWell square UMAS;10;;100;;;;;
A;Source;;96 Well DeepWell square UMAS;7;;100;;;;;
D;Dest;;96 Well DeepWell square UMAS;11;;100;;;;;
A;Source;;96 Well DeepWell square UMAS;8;;100;;;;;
D;Dest;;96 Well DeepWell square UMAS;12;;100;;;;;
This runs and works, but it only uses the first tip. I have all 8 tips selected in the load worklist command and I used the “GetDITI” and “DropDITI” buttons and set them to all 8 tips. But the script runs using only the first tip.
I tried adding the tipmask in there like this:
A;Source;;96 Well DeepWell square UMAS;1;;100;;;1;;
D;Dest;;96 Well DeepWell square UMAS;1;;100;;;1;;
A;Source;;96 Well DeepWell square UMAS;2;;100;;;2;;
D;Dest;;96 Well DeepWell square UMAS;2;;100;;;2;;
A;Source;;96 Well DeepWell square UMAS;3;;100;;;4;;
D;Dest;;96 Well DeepWell square UMAS;3;;100;;;4;;
A;Source;;96 Well DeepWell square UMAS;4;;100;;;8;;
D;Dest;;96 Well DeepWell square UMAS;4;;100;;;8;;
A;Source;;96 Well DeepWell square UMAS;5;;100;;;16;;
D;Dest;;96 Well DeepWell square UMAS;9;;100;;;16;;
A;Source;;96 Well DeepWell square UMAS;6;;100;;;32;;
D;Dest;;96 Well DeepWell square UMAS;10;;100;;;32;;
A;Source;;96 Well DeepWell square UMAS;7;;100;;;64;;
D;Dest;;96 Well DeepWell square UMAS;11;;100;;;64;;
A;Source;;96 Well DeepWell square UMAS;8;;100;;;128;;
D;Dest;;96 Well DeepWell square UMAS;12;;100;;;128;;
But when I do that the script throws an error and tells me to check the log. I can’t find any error in the log and when it takes me to the screen during the beep where it lists all the variables in the bottom right the LAST_ERROR says “NO ERROR”. SO I am not sure what even the error is.
What am I doing wrong with the tip mask?
There’s something about making a forum post that seems to always lead me right to the correct answer. Right after I posted this I tried adding a W command between each set of A and D and it started using all 8 tips. Then I put the tipmask back in and it had no problem with that either.
I am still unsure what the error was about in the second worklist. If anyone can help me understand I would still greatly appreciate it.
Hi!
When I have worklist error like this, I usually check my format first to see if I have any extra “;”. It looks like there is an extra ; at the end after Tip Mask values. Let me know if that is the case, I definitely had similar issues before.
A;RackLabel;RackID;RackType;Position;TubeID;Volume;LiquidClass;TipType;TipMask;ForcedRackType
