Execute VB Script in EVOWare
Hi, Everyone!
I’m trying to run a VB Script in EVOware that changes the Ws to Fs, but I can’t seem to find the “Execute VB Script” command that’s in the manual and that I used in FluentControl. I’ve already tried right-clicking the Programming section and clicking on “Show hidden items”, but it still didn’t come up.
Based on a section in the Help section of Evoware, do I need to somehow get the VBscript into the database?
Any help is greatly appreciated!
Hi @julu25
The EVOware installation disc contains two EVOware installers, one for a EVOware research use only version and another one for a EVOware for clinical diagnostics version. If the EVOware Clinical Diagnostics version is installed, some commands are missing because they are not allowed in this setting. Besides Execute VB Script, I could imagine that also Execute Application or the Miscellaneous - Command (for sending firmware commands) are probably missing when you have the clinical version installed. In the EVOware Menu - Help - About it can show you which version you have installed
Thank you!
