Hi everyone,
Does anyone know how to enable the use of lld_mode in the visualizer?
Reproduction code:
from pylabrobot.resources.hamilton import STARLetDeck
from pylabrobot.liquid_handling.backends import ChatterBoxBackend
from pylabrobot.resources import (
TIP_CAR_480_A00, PLT_CAR_L5AC_A00,
STF_L, HTF_L,
Cos_96_DW_1mL
backend = ChatterBoxBackend()
lh = LiquidHandler(backend=backend, deck=STARLetDeck())
await lh.setup()
tip_car = TIP_CAR_480_A00(name="tip_carrier")
tip_car[0] = tiprack_300ul = STF_L(name="tip_rack_01")
tip_car[3] = tiprack_1000ul = HTF_L(name="tip_rack_04")
plt_car = PLT_CAR_L5AC_A00(name="plate carrier")
plt_car[0] = plate_1 = Cos_96_DW_1mL(name="aspiration plate")
lh.deck.assign_child_resource(tip_car, rails=1)
lh.deck.assign_child_resource(plt_car, rails=21)
await lh.pick_up_tips(tip_spots=[tiprack_300ul.children[0]], use_channels=[0])
await lh.aspirate(
use_channels = [0],
vols=[100],
lld_mode=[lh.backend.LLDMode.OFF]*no_channels,
returns error…
AttributeError Traceback (most recent call last)
Cell In[1], line 32
24 lh.deck.assign_child_resource(plt_car, rails=21)
26 await lh.pick_up_tips(tip_spots=[tiprack_300ul.children[0]], use_channels=[0])
28 await lh.aspirate(
29 [tiprack_300ul.children[0]],
30 use_channels = [0],
31 vols=[100],
---> 32 lld_mode=[lh.backend.LLDMode.OFF]*no_channels,
33 )
AttributeError: 'ChatterBoxBackend' object has no attribute 'LLDMode'
At the moment we have to comment this line out whenever we want to test the same code we also want to use on the machine.
Is there a simple way to make the visualiser (/lh.backend==ChatterBoxBackend) tolerate all surplus attributes from different machines?
