Was just wondering if there is a way to lock fluent controls window when copying and pasting script steps. When moving blocks around or copying/pasting the entire frame jumps, and suddenly you’re no longer looking at the same lines of code as you were before. This makes it really hard to figure out where things are going when you copy paste. Was wondering if there was a hack to lock the frame of view?
Colin
I cannot see an issue from my side (with FC 3.6), when I select one or multiple script lines to copy with Ctrl +C, then if I want to insert these copied script lines after let’s say script line #50, then I click on line 50 so that script line becomes highlighted white, then Ctrl +V and the copied lines are pasted after line 50 and the view stays as is on the highlighted line 50 without movement of script lines.
I have seen sometimes that script lines started scrolling itself slowly towards the bottom and I couldn’t stop the scrolling with the mouse. Finally had to scroll myself to the bottom of script first before I could scroll up again. But that happens to me very rarely (it usually takes like a few weeks until I see it again, hence it didn’t really bother me too much).
Interesting, same software version on my personal laptop, do not have the issue. Seems locked to that PC/Installation.
