Fluent ID Deck Flexibilty
Considering implementing a Fluent ID tube rack barcode scanner on my system. I’m curious about the deck layout flexibility and how things are wired.
How much effort is it to take it out for another assay that uses a different deck layout? Would you recommend keeping it fixed once installed?
the module itself can’t be unplugged without causing issues with communication,
but in theory, you could remove from the deck & carefully locate it somewhere off deck
