GBG Link Identical/Redundant Systems
I’m brand new to GBG and most schedulers, and I am only simulating a potential build at the moment to sketch out my assays.
Is there a way to link/mark similar instruments? For example, I have 2+ Bioshakes. I currently have to designate which shaker each labware should use in a given incubation step. If I want to run multiple iterations, each plate waits for the first shaker to be free even though there are several not in use.
How do I program my workflow so that any available shaker is available for use?
I think I can use conditionals to check for device availability and use the next available, but I am curious if there is a command that would simplify that action.
you can create an “instrument pool” for the shakers
this gives the scheduler the ability to change the chosen resource based on availability
Yeap, GBG makes this simple with the instrument pool task.
