Hello All,
I am just wondering if anyone here use Hamilton scheduler. we are writing a complex procedure and wondering its good to use Venus or use Scheduler. AS this system will have robotics arms and several other equipment attach to it.
Any thoughts/suggestions/expiernce will be appreciated
Thanks
Its up to you to determine if your process would benefit from scheduling over a linear process. If your process is static and the throughput low you can write an optimized linear method. The more plates and more variability from run to run you’re going to want scheduling. The Hamilton Venus scheduler is great for building complex workflows with many off deck integrated devices.
