Hamilton Star Operating Humidity
I have a quick question about Hamilton Star Operating Humidity.
On this website, Hamilton states that the operating humidity is 30%-85% without condensation (
Microlab STAR Site Requirements)
On the main Hamilton website, the operating humidity is listed as 15%-85% without condensation (https://www.hamiltoncompany.com/automated-liquid-handling/compare-platforms)
Which range is accurate?
Thank you!
The operator’s manual states 15 to 85% (non-condensing) so I would go with that. I will let Marketing know about the discrepancy on the website.
Please note that the STAR is for indoor use only. I know a lot of customers would like to take their STAR outdoors to get some fresh air from time to time, but this is not recommended.
This brings up an interesting point, if you are using a STAR in a higher altitude area are there any mitigations you recommend to customers? Colorado Springs is close to that altitude in sea level, for example.
From a liquid handling perspective, you would see the following general behavior:
  • As elevation increases, average dispense volume decreases (Altitude high → air density lower → spring force lower → dosage lower)
  • As temperature increases, average dispense volume decreases (Temperature high → air density lower → spring force lower → dosage lower)
  • As humidity increases, average dispense volumes increases (Humidity high → air density higher → spring force higher → dosage higher)
So these factors would affect the trueness of the pipetting and you would likely have to adjust the correction curve accordingly in the liquid class. I would not expect the precision to be affected.
Don’t forget about our favorite friend static electricity. Low humidity causes low volume dispense to be less accurate.
