I’m trying to write a method for my Vantage which will transfer samples from 1.5 mL Eppendorf tubes into a 384W Echo LDV Plate using the channels with 50 uL tips and I’ve been running into issues with channel alignment being off in the Y and causing the tips to clip the sides of the wells. Image attached of how the channels look in the plate, specifically noting the misalignment of ch 2, 4, 5, 6, 7. I’m seeing the worst clipping on channels 5 and 7. Our service engineer has come in to realign the channels a few times with AlignPip and according to that it is within tolerance but I am not seeing any improvement.
For reference, I am picking the tips up from a Tip Support and am using a labware file for the plate provided by Hamilton. Plate is being taught in A1 using the channel + teaching needle.
Is this as good as its going to get from the Vantage? Has anyone else successfully been able to pipette into this plate or have any tips otherwise?
