Hamilton VENUS prompt, make Image visibility depend on pull‑down selection
I am using Hamilton VENUS 6.2.1 Prompt Designer. In a single custom prompt I have a pull‑down bound to a numeric variable StartColumn with values 1..12 which controls a “Sequence: Set Position Current” function.
I want to display an image based on the users choice in the above mentioned pulldown.
In the Picture control’s properties I only see a “Visible” checkbox. It allows you to bind to a variable but ideally the choice of the user in the pulldown would be updating while the prompt is open.
  1. Is there a way to bind the Picture control’s Visible property to StartColumn or an expression like StartColumn = 3?Processing: Hamilton_GSD_12.png…
  2. If not, can Visible be bound to a Boolean variable per image, and will it update without closing the prompt?
  3. Alternatively, can the Picture control’s image path be bound to a String variable so I can swap a single image at runtime?
Any pointers on the exact property names or settings in VENUS 6.2.1 would be appreciated.
Hi @caradonna1,
Unfortunately, it is not possible to have another object’s properties change based on a specific selection from a drop-down menu without first closing the dialog and binding the selection to a variable to appear in a new dialog. For any object in the custom dialog, there is a tab for Events that lists the available actions for an object which can affect another object’s properties. For drop-down, the only options are Mouse Enter, Mouse Leave, and Selection Changed, so while an object property can change when a user changes the selection, it can’t be based on the value selected (StartColumn doesn’t store the value until the dialog is closed).
To answer your questions directly:
  1. Yes, but only by closing the dialog, which will store the selected index in the variable StartColumn, then using logic to toggle a set of booleans each bound to an individual image, then re-opening the same dialog or opening a new one.
  2. No, the way to achieve something like this without closing the dialog would be to use radio buttons instead of a drop-down, in which each radio button has an event that sets the target image visible when checked then sets the target image invisibile when unchecked.
  3. Yes, the image path can be bound to a variable so a single image changes at runtime. The “Image” property under “General” has a drop-down which allows embedding or linking new images. This will attach the image to the custom dialog, which can later be referenced by a variable that contains the file name of the image of interest (the following text is from the Help file):
{CB8736B1-3D9B-4313-8977-C834DC4BA9CA}
