Yes, I tried,
but I have no idea how to scan a barcode and match it between the tube and the Eppendorf, then proceed with the transfer.
I understand how to perform a simple transfer by entering the sample number through the UI and transferring from the tube to the Eppendof tube during sequencing.
here’s how i would do it:
-store scanned 10 mL tubes into an array
-store scanned 1.5 mL tubes into an array
-create 2 new sequence (_asp and _disp)
loop through 1.5 mL and compare with 10mL tube array. If it matches, add those sequences
