Help with a capacitive liquid level detector
Apologies if this is in the wrong section of the forum, I wasn’t sure exactly which section it would fit best in to. I’ve been trying to install a gravity waste trough for a Microlab Star, I believe the part number is 92581-01 but I might be wrong. The trough itself has been set up, but I’m having difficulty with the capacitive liquid level detector. The detector itself is a non-contact one which is already set up on the side of the trough, leading out to a short six-pin connector. I was also supplied with a cable that turns that into a different form (picture of cable attached). However, I can’t find anywhere that the second form would plug into - either on the computer or the star. Do I need some sort of adaptor, am I just not spotting the correct port, is it a wireless module?
In addition, once the sensor is physically linked, how do I access and take readings from it within Venus?
Any help would be greatly appreciated
Tarun
Hi Tarun,
The sensor that comes on the carboy for the gravity waste is not used. The field teams are instructed to remove them during installation. If you need to get in touch with your local support team, please feel free to message me!
-Eric
Hi Eric,
Thank you for your help, thats good to know. Does that mean I just keep an eye on the level manually instead? We have someone coming relatively soon anyway for other deck installations, so provided its not urgent that it be removed then I’ll just wait until then.
Best Wishes
Tarun
Correct
Have read the gravity waste sensor but only by connecting through the PCB that’s part of Liquid and Tip Waste System 54698-01.
@EricSindelar_Hamilton I have a question. I was looking to add gravity waste to two Hamilton Vantages that currently do not have them. I received a quote with 2 line items:
  • MFX Gravity Waste Module (92581-01)
    • Contains the MFX module for the deck, Gravity waste drain, waste bottle, and tubing
  • ASSY, LIQ WASTE, 9L, 3.5L-SENSOR (96717-01)
    • Is this sensor programmatically available through a library?
    • If not, what is its purpose?
The ASSY, LIQ WASTE is just the carboy that comes with a sensor by default. The sensor is not used though and serves no purpose for this specific module.
Thank you Eric as always for your quick/helpful replies! The wording for the MFX module was unclear, so I appreciate you confirming this.
