HighRes Microspin Door stuck
Has anyone experienced issues with a Microspin door failing to open or close properly? My Microspin door is currently stuck in the open position. When I attempt to initialize the system, the door won’t close and generates an error message. After disconnecting both power and air supply, I tried manually moving the door but encountered resistance at a certain point, beyond which it refuses to move. I’m wondering if this is a mechanical obstruction or another type of failure.
