I am currently testing the HSLHttp library for the first time in order to receive data directly from our LIMS. The LIMS offers a SOAP API which should be fine because the HSLHttp library supports xml.
However, we need to work with encrypted messages, but I am not sure if the HSLHttp library also works with https urls. Does it? Or is there another library which can be used instead?
Thanks for your help in advance
Martin
