I am reading a .xslx with Tecan Fluent and it is taking 3 minutes to read 96 rows. Is this normal? The file is a single column with all floating points. Is there a way to speed this up?
Yeah - don’t use import variable
it copies the file at every line/row import
i would recommend array update from an external application (.vb) to handle the values being imported
Lol no way… Are there any guides on how to do that? This method was setup from Tecan this way, I have 3 files to load so its taking me 10 minutes just to trouble shoot the file I/O to fix an issue with in the method. ![]()
this forum has various examples for FluentControl arrays
the Tecan scripts for Robocolumns are pretty basic for scripting and not efficient for good chromatography practices
Thanks for the quick response! Thank you, didn’t realize this was such a common work around. Found a few examples on the forum thanks! Crazy I took the intermediate course but it did not cover anything even close to this, not even File I/O was covered. Really appreciate the help!
I may have some super old Excel code laying around if you’re still interested
@luisvillaautomata any code would be appreciated. I don’t see a section in the manual for executing VB.net.
I’m really unfamiliar with Tecans. It looks like to me at least for the Evo, maybe the Fluent, the ideal workflow as an advanced user is to do a lot of your logic operations in VBscript then pass this to the Tecan? Is this safe to say?
Actually I think this thread gets me 90% there, I’m reading magellen files: Accessing magellan results in fluent control script - #2 by Optimize
Yep. You can execute VB.NET scripts through the Execute VB command under Programming.
If you’re a script kiddie, you can do some amazing things with extremely simple VB. However if you know your way around software, you can unlock pretty much any functionality or use any modern tool.
With that said, there are some good forum threads here but IMO this forum is not necessarily a good place for sharing knowledge in a way that teaches people. I’m going to publish a substack soon where I hope to aggregate a lot of information (github linked), blog about papers I read and hopefully teach folks some best practices.
Imports Microsoft.VisualBasic
Imports System
Imports Tecan.Core.Scripting
Imports System.IO
Imports System.Net
Imports System.Collections
Imports System.Collections.Generic
Public Class TestClass
Implements IScriptObject
Private Host As IScriptingHost
Public Property ScriptingHost() As IScriptingHost Implements IScriptObject.ScriptingHost
Get
Return Host
End Get
Set(ByVal value As IScriptingHost)
Host = value
End Set
End Property
Public Sub Execute() Implements IScriptObject.Execute
' Set Excel file path in Tecan Fluent for the variable pathExcel
Dim pathExcel As String = Host.GetVariable("pathExcel")
' Set CSV file path in Tecan Fluent for the variable pathCSV
Dim pathCSV As String = Host.GetVariable("pathCSV")
' Set the range of the Excel file to be read (e.g., A2:B2) (can be variabilized ranges)
Dim rangeExcel As String = "A2:B2"
'Boiler Plate code to open Excel file & Worksheet
Dim xlApp As Object = CreateObject("Excel.Application")
Dim xlBook = xlApp.Workbooks.Open(pathExcel)
Dim xlWorksheet = xlBook.Worksheets(1)
xlApp.DisplayAlerts = True
xlApp.Visible = False
' Read the data from the Excel file
Dim dataRange As Object = xlWorksheet.Range(rangeExcel)
Dim dataArray As Object(,) = CType(dataRange.Value, Object(,))
Dim valueExcel
' Open the CSV file to write the data
' Dim sw As StreamWriter = New StreamWriter(pathCSV)
' Dim output As String
For i As Integer = 1 To dataArray.GetUpperBound(0)
' Grab value from cell in Excel Worksheet
valueExcel = dataArray(i,2)
' Write the data to the CSV file
' Modify the output format as needed
' output = i & ";" & valueExcel
' sw.WriteLine(output)
' Or set the data to a variable in Tecan Fluent
' Host.SetVariable("variableNameFromTecanFluent", valueExcel)
' Or set the value to an array in Tecan Fluent
' Dim arrayTecan = "Array[" & i & "]"
' Host.ResolveExpression("arrayTecan:=" & valueExcel) 'This may require actual execution and debugging in Tecan since I don't have an Excel file on me
Next
' Close the CSV file if writing to a file
' sw.Close()
' Close the Excel file
xlApp.DisplayAlerts = False
xlBook.Close
xlApp.Quit
End Sub
End Class
Uncomment the items you want to test.
There’s a Touch Tools command for selecting a file.
Three tests
Three line tetsing script.
