Anyone have the installer for HamiltonDriverTools version 4.5?
Thank you Eric!
Do you know if 4.7 is for Venus 6v spefically. The instrument we are having issues on is Venus 4. Also, is there an updated Inheco installer that need be updated with the new driver tools version?
Hi Justin,
If you are referring to using the Inheco ODTC, the ODTC driver you would want to use will also install the respective version of DriverTools. For example, ODTC v1.9 will install DriverTools v4.7. And ODTC v1.1.1.3 will install DriverTools v3.2. So when you install the ODTC driver it might be better to first make sure you also don’t have DriverTools already installed on the target PC as well as make sure there are no “Hamilton DriverTools” folders in the library/methods folder. I added methods folder because sometimes method imports like to place another DriverTools folder there.
Matt
Thank you Matthew,
Any chance that we could get installer 1.9 as we have the old version 1.1.1.3 and would love to get our systems on te latest. So our hypothesis seems to be correct that we had an incompatability between the DriverTools 4.5 and the 1.1.1.3.
So is ODTC v9 the latest and greatest?
Justin
