I’m using cLLD to measure the height of liquid in a well. cLLD works fine for me for liquid following but the height its reporting isn’t possible unless I’m mistaken on what it’s supposed to be reporting.
Here’s an example
2026-02-20 21:07:15.620 Microlab STARlet : 1000ul Channel Get Last Liquid Level (Single Step) - complete; > channel 1: 189.8 mm > channel 2: 190.2 mm > channel 3: 190.6 mm > channel 4: 191.0 mm > channel 5: 190.9 mm > channel 6: 191.0 mm > channel 7: 190.4 mm > channel 8: 190.3 mm
The tip goes to the correct position in the well. Is the height that it’s reporting literally the height above the deck zero point? That interpretation would seem to make sense but is somewhat inconvenient to work with.
