Is it possible to disable cover control through Venus for Vantage?
is it possible to disable cover control through Venus for Vantage?
Yes you can go to the tools configuration editor on Venus. You should find the cover monitoring option under “ML Star” tab. I don’t have a vantage under my eyes, but I know it’s there.
Side note : it’s not like the STAR where you have to change something in the star service. Disabling the cover monitoring can be done just through the tools configuration.
Best
I use two neodymium magnets about this size: 9625 - Neodymium Magnet Block N35 50MM X 10MM X 2mm(A) - Radial Magnets - We Know Magnets
If you fiddle a bit, its not hard to fool the system. It helps if you don’t strictly have the permissions to change the settings.
