Issues with generating mapping file
Hi All! I’ve run into an issue generating a mapping file at the end of my protocol. For some context, I have a sequence loaded that contains every position for 10 384 well plates on the deck, which may or may not be used. For this simulation run that I’m testing, only 2 of the 10 possible 384 well plates are used. The issue arises at the end of the protocol when I am trying to generate a mapping file that shows which well of my 96 well plate went in to which well of the 2 384 well plates (only 384_TC_0001 and 0002 were used):
The error description is: C:\Program Files (x86)\HAMILTON\Library\HSLMappingReportImpl.hs_(1677) : _Method::STCC::HSLMapReport::GenerateMappingFileV43() The labware ‘ML_STAR\APE_CARRIER_01199\MJR_384_TC_0003’ is not present. (0x0 - 0x0 - 0x6)
I had this error on another generate mapping file earlier on in the protocol using the same target sequence (I broken up the protocol into groups “adding master mix” and “adding DNA”) but somehow I fixed it and I don’t know how…
Any advice would be greatly appreciated! Thanks!
Just wanted to update for anyone possibly having the same issue - I was able to figure it out. To generate the mapping file you have to have loaded ALL the labware using the load step, not just the ones being actively used. Because I knew from my worklist I was only going to have two 384 well plates be used, I only loaded 384 well plate 0001 and 0002 instead of all 10. Once I added the other 8 plates it worked fine.
