We have a Janus automated liquid handling system that we have been trying to set up for a DNA extraction protocol. We have been running into some issues though and were wondering if anyone had any insight.
(1) The first issue we encountered was programming a step for supernatant removal. We were thinking about dispensing waste into a reservoir trough. However, it seems that the program considers a trough as one well and will only dispense one adapter per trough. For example, we want to remove the supernatant out of eight samples and we have two designated troughs for waste. When starting the program, the varispan head will only pick up two tips, remove the supernatant from two samples, dispense supernatant from one tip per trough, drop the tips, then grab two more tips and repeat this process again. If we have three troughs, it will grab three tips at a time and remove and dispense supernatant from each tip per trough. Hopefully this makes sense. A message will also pop up stating a labware change request for the trough every time the varispan head goes to grab new tips. It seems the program does not like using the trough as the location of a dispense.
The goal was to use all eight adapters simultaneously and dispense our waste into one trough, to speed up the process.
We have also attempted to dispense waste into the flush/wash basin, but again it seems to consider this as one well and so will only put one tip per well. If you have any suggestions to remedy this or an alternative method to removing and dispensing waste, we would love any input
(2) Another issue we have been having is the addition of new labware that is not already present in the software. We are using a VWR 96 deep well plate and this is not already pre programmed. We know how to alter the 3D dimensions of the labware we newly created. Based on the dimensions of the other plates, we thought the units of the dimensions were in millimeters. Yet when we measure and input the dimensions of our new plate, they seem to not be accurate in practice. We have resulted in blind trial and error, running a program, doing slight adjustments based on what we see, and running it again, over and over. It’s been very time-consuming. Let us know if you have any advice or knowledge about creating a new labware or if there is a resource that already has these dimensions and can be uploaded online.
Thanks you guys!
