Lab Equipment Sale: Hamilton [MPE]² & More – Great Deals!
For Sale: Hamilton Monitored Multi-Flow Positive Pressure Evaporative Extraction (MPE)
Starting Bid: $960
Link to eBay Listing: MPE Hamilton | eBay
Description:
We are offering a Hamilton Monitored Multi-Flow Positive Pressure Evaporative Extraction ([MPE]²) unit.
Key Features:
Precise Positive Pressure: Ensures consistent and reliable sample evaporation.
Multi-Flow System: Allows for flexible and efficient processing of multiple samples.
User-Friendly Interface: Easy to operate with intuitive controls and monitoring.
Versatile Applications: Suitable for various laboratory extraction and evaporation needs.
Condition:
The unit is in excellent working condition.
See additional listings hex-07 on eBay
Equipment list: systems located in the Menlo Park area
  1. I.DOT #1 - SN: i2-201003
  2. I.DOT #2 - SN: i2-211200
  3. BioSpot - SN: BS-2023-12-1-01
  4. Meniscense - SN: 2022-005
  5. Inheco IS-DWP up to 12 - SNs: 408, 442, 443, 446, 449, 450, 460, 453, 432, 448, 454, 447
  6. MPEs x 2
Hi @dchinn1490
I am interested in the Hamilton MPE2 although I am curious on what does “monitored multi-flow” exactly mean? Like each well or column can have different flow rate that the device can monitor simultaneously?
-Nat
Hi Nat,
Thank you for your inquiry. For the most accurate information regarding the “monitored multi-flow” feature, I would recommend reaching out directly to Hamilton. You can find more details here: Hamilton MPE2.
How can you say it’s functioning as intended if you can’t explain one of the main features? Does the unit come with a warranty?
[quote=“Nat, post:2, topic:4257”]
Thank you for your question!
To my knowledge, “monitored multi-flow” does not mean that each well or column can have a different flow rate that the device can monitor simultaneously. This description comes directly from the Hamilton team, and we don’t have control over how they describe their items. The vendor may have better insight into the specifics of this terminology and how it applies to their products.
Best regards,
Item does not come with a warranty.
Warranties are generally through the manufacturer, but most manufacturers don’t honor warranties for items purchased on eBay unless the seller is an authorized retailer for the product.
you can purchase high quality lab equipment with southern labware
“Multiflow” here indicates separate air paths for the dispense pins. If have the 96 well plenum and one is clogged, the other 95 will still deliver.
