I recognized that some of the labware 3D data models are stored as .x and others as .hxx files.
I can access the 3D of .x files, but .hxx files seem to be special.
Do you know what the difference of these data files is and if there is a way to convert .hxx into .x files?
Direct X (.x) files can be exported by versions of Blender 2.79b and earlier, which is a free and prevalent software widely used for generating 3D models, renderings and animations. You will need to activate an internal plugin to enable export of .x files.
Blender supports import of tons of different drawing file formats, so you can use pretty much any modelling software you want/have access to in order to generate the drawing if you don’t want to use Blender as the primary modelling software. Just be sure your model is properly scaled in mm.
Once generated, you can associate the .x file as a 3D model in any .rck, .ctr, .lid, or .tml labware definition. Dragging the definition on deck will allow you to view the drawing and see if it meets your desired standards. Sometimes I just copy an arbitrary labware definition and associate the .x file I am interested in and use the deck editor as a viewer. If you wanted to use an alternative method, a quick google search will likely yield tons of free online file converters.
Regarding generating drawings in modelling software, there are tons and tons of online resources (youtube) that provide exhaustive tutorials.
Note that the data within the .x file is used purely for cosmetic and rendering purposes. The data within the file has absolutely no impact on the labware definition parameters, and cannot be used as a substitute for defining the labware.
This allows exporting .x files, but still no import. I’ve made some custom labware for which I would much rather edit an existing file than start from scratch.
I have tried creating DirectX files from Blender 2.79a on Windows, but the model fails to render in the Hamilton Deck Editor. The rectangles representing the labware template positions are there, but the 3D model is not rendered at all.
Looking through the Blender settings and DirectX plugin settings, I have a few questions:
(1) Should I set the units to “Millimeters”? The model was originally made in a CAD program with the units defined in mm.
(2) What is the proper orientation of the model? When I imported the model into blender (it was exported from CAD as an FBX file), the model was oriented such that “up” was in the negative Y direction. Should the model “up” orientation actually be in the +Y direction?
(3) For the DirectX export options, which options need to be selected? Are the defaults OK? If I have the the “Up Axis” option as “Y”, then should my example model be rotated 180-deg in the Z-axis so that my model “up” orientation is in the +Y direction (see last image)?
There is a way to get current Blender set up to export .x files, but it takes a little plugin modification to make it work. All of this is dependent on you having a model of some type imported (or designed) in Blender.
I used this repo as the base, but had to modify a few parts to get it working. It’s been a while, but if I remember correctly, the “use_auto_smoothing” property for meshes does not exist anymore, so this has to be worked around. Again, if I remember correctly, I just removed an if statement and used the normal from the mesh’s vertex array.
In addition, I’m not sure if it’s a mistake in the original plugin, or just a difference with the Venus UI, but the green and blue color channels for textures need to be swapped or your color will be off.
You will have the best results if your model file only contains quads and tris. It doesn’t do a great job of processing n-gon faces.
If you’re interested in importing x files to Blender, this repo is also a good base to start from:
As with the export plugin, this requires some modification. If the model is split into multiple meshes, they will all share an origin of (0,0,0), so it can be a pain to realign the model properly. I’ve also seen some issues where the Y-Axis scaling is off, but it was always consistent. This one also fails with n-gons, but with some modification, you can at least get it to import the n-gon faces as a triangle fan, but that doesn’t always result in a useable model.
I checked code of the project DodgeeSoftware/io_scene_directx, and I don’t think it can import model to Blender, because there is no code to parse model.
Following is project that can be used to import x file to blender.
I did not test this project in Blender, but I am sure that it should work. For I ported it to javascript and it can load x file and display all the Hamilton x file in browser.
Yes, there is no actual code in the import from the first repo, that is why I included the second one. It looks like the one you included may be better than the spamandeggs one however.
