So I was using the method editor and my deck has been defined, and what if I wanted to add four different liquids (of different kind and volume) from different location to for example corning 96b well plate from position A1 - 10, and durning the next iteration like jump row B and add it from c1 - 11 and last iteration add one liquid (of different volume and kind and position) and add it only to one well D10. For all I want to change the tip like for example if I am adding buffer into 10 well plates I change tip and add acid, and so on. I would gladly appreciate your help :))
