Is this in a simulated environment? The LoadAndMatch Powerstep will only return values for barcodes that have been matched with the worklist. In simulation, the barcodes are always read as “Barcode01”, “Barcode02”, etc. Unless your worklist is using those values, it has nothing that can be matched.
sadly im not in simulation mode.
I will for now just continue without using the powerstep and try to do it with simple steps.
I have a Hamilton representative in house in 2 weeks if we cant find a solution here, i will ask them to help me out and im gonna post the results here.
Edit: I should clarify that the “scanned barcodes” output array of the power step is empty in real runs though other outputs like “barcodes without match” get populated. Running in simulation returns the expected “Barcode01” etc. and matches them successfully to my dummy worklist.
