I am wondering if my lab has the current LVK software. This is the version of the software that came with our LVK:
If this isn’t the latest software, where could I download the newest version?
That is the most recent version. The installer version is 3.1.
Can you please provide more information? When do you encounter the error?
VENUS version, OS version, lVKUIlog.txt indicated in the error message, etc. would be helpful.
You can upload files here. Password is Hamilton23.
Eric
All relevant files are uploaded.
Thank you for uploading the files. The issue you’re having is due a patch required in order for the LVK to work correctly with VANTAGE installs.
Documentation on how to download/setup the patch can be found at this link.
In case there are issues with the download link in the documentation, you can alternatively use this link to download the patch.
Let us know if you run into any issues during setup.
Thank you @EricSindelar_Hamilton and @DanHartman_Hamilton! This fixed my issue!
@DanHartman_Hamilton, is this patch necessary a Vantage running Venus 6? Or only on Vantages running Venus 4/Venus 5 VOV?
Hi @UCantBcereus,
This patch is required for any version of VENUS/VoV when using the LVK with a VANTAGE.
Hi @DanHartman_Hamilton and @EricSindelar_Hamilton ,
has there been any updates to the lvk software? I am running version 1.3, which predates the fluid motion channels and they don’t seem to be compatible.
Thank you!
There is a pre-release version that I can share with you. I will send you a direct message.
