MPE error
Hi there,
I was half way through a method that used the MPE2 positive pressure manifold.
I have run 6 rounds of filtration that all worked fine.
Now I am getting a strange error.
I have removed the filter plate, it re-initializes properly without error, but when I resume the method, I get the same error again.
Any help interpreting this error message would be great.
@awaller - Troubleshooting errors without context of the command that failed along with a trace file is difficult. Usually the error message alone is not sufficient to identify the issue.
Can you please provide a trace from the run that errored?
Hi Nick,
I found the error in the trace file.
I had mistakenly changed one of the MPE times to 0.
Thanks
