Multi dispense librairy
I have a worklist with 200 volumes to dispense, ranging from 80uL to 1800uL.
Therefore, some volumes fit in a 1000uL tip and some need several aspiration/dispense.
Is there any library to handle that or do you guys make your own logic (if below 950, aspirate the whole volume, else, volume = volume/2 and put a loop =2).
Thank you
Hi @KevinJ
Check the linked post below. I think the library provided there should suit your needs or get you pointed in the right direction.
That is great! Thanks a lot Nick!
